Add Comments to Rung text import? (Studio 5000)
yes
create a basic ladder file with comments where you want them etc
Save as L5K - Open in your favourite text editor and find the comments.
Do as Michael G said -- Export a dummy program that has some rung comments to L5K to an L5K to get the format. I don't have Studio on this laptop, or I'd tell it to you.
You can paste multiple lines from Excel, if each row of code ends with a semicolon so that the Studio interpreter can recognize the line break. I've successfully pasted in >100 lines in one shot.
Good luck
I'm doing an address conversion between a messy system and an organized one so I have a Excel sheet that generates a SOR XIC OTE EOR for each rung. I take the output and paste it into a rung and that process generates all the rungs I need. I have never tried to create an L5K file from this method, but I'm sure others smarter than me have, and I have a bunch more to do so I'd like to learn this power.
I'm home so no access to my system either, can someone export an L5K with just a couple rungs of XIC and OTE with Tag descriptions and a Rung Comment so I can experiment and see how that might be created from Excel ?
If that turns out to be possible I'll then have to figure out how to add branches since the analogs get arranged into several MOVS per Rung/Branch.
(if only branches could have their own comments... alas )
I don't think you will be able to do that, when you have done all your conversions put comments on 1 rung and export tag database, you can then see the format and update all the other tags in the database and import them back into the project.
It better to have too many instead of not enough right?
26
2,894
Hi , I am not able to expand any global variable in offline mode, also not able to add comments to the elements of the variable since it does not...
3,235
I usually do not share my Excel macros but in this case I feel the need to help others who got screwed by Rockwell Software. Unknown to me at the...
4,946
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
119
