We have some large horizontal machining centers for drilling castings. They have custom built hydraulic clamps in the stations. We've had issues where operators would not tighten the clamps tight enough or not at all and damaged bits or even damage spindles.
We are wanting to add Bluetooth pressure transducers. I know Bluetooth isn't the best method but it has to be wireless because the fixtures will turn 360° and then switch stations and repeat, so it can't have wires.
We have a single transducer on one of the clamps on there now but we can only use an app to look at the data on a smartphone or tablet. We wanting to use the data to prevent the drilling cycle from starting if any clamp is not tight enough.
I'm thinking about using a Meas M5600 transducer or something similar.
Has anyone done something like this? What PLC or interface did you use? What about an Arduino based PLC that has Bluetooth or add a Bluetooth module. How do I get the data to the PLC?
If I could find a transducer that had an adjustable setpoint and just gave a 1 or 0 would be great. If I have to use the analog data that would just make it more complicated. Whatever method is easier is what I'm wanting to do.
Any suggestions? A different method? Is there a way to use an Allen Bradley PLC and adding a Bluetooth module? How would you do it?
Any help greatly appreciated.
