Adding comments/destriptions in module defined data type tags?
PreLC
Apr 2019
Mars
587
Hi PLCs.net!
I'm using Studio5k V32, and I have an EDS file for the Fanuc 30r-ib plus controllers.
I have an excel spreadsheet with bitwise description of 10 bytes of data for input and output each. Is there a way to get the IO descriptions out from fanuc and into the tags?
I have already manually copied them over, but I was just wondering if there is a better way?
Regards,
-PreLC
I suppose you could write a VBA script to poke the descriptions into a Word copy of the L5K export file, but it sounds like a lot of work, and as you say you've already manually inserted the comments/descriptions.
Perhaps get it ready for the next time ....
I'm using a global DB as the i/o for some FBs (thank you, JesperMP). As I only need six bits for each FB I started with a byte as the input/output...
3,269
Hi, I use Excel to write some routines and was wondering if it is possible to add rung comments when doing so? Excel function: ="MOV "&[@[Range...
2,550
I am using RSLogix500 V.8.10.00 (CPR9). I know how to add comments or discriptions to the programs on my computer, but how can download them to...
1,898
I'm trying to add comments to a program already written, doing what I can to make it easier to understand what the coils actual refer to. But I...
4,386
I have created a UDT import file for RSLogix 5000 that imports a bit overlay UDT. What I can't find is how to add documenting comments to the XML...
6,036
