Hi it's my first post so go easy on me guys, my experience of PLCs has mainly been using for fault finding and a few minor mods up until now.
My manager has given me a project. We have what is called a spiral freezer which is basically a conveyor belt in a freezer that takes around 2 to 3 hours(depending upon speed setting) from start to finish.This spiral is used to freeze down meals ready for packing.
We have lots of problems with jam ups that loose us a lot of money both in product and time.
What he wants me to do is devise a system that monitors meals going into the spiral and check that they should come out when they are supposed to.
I have built a prototype using an FX2N-32MR-ES/UL(Our supplier gave us this model cheap as it's ex demo if you're wondering why I need so many IOs)
I decided the way to proceed was using a bitshift to divide the residence time into minute segments.I used relays M000-M180 ie if the residence time is 120 minutes when the trigger bit goes high(in this case M120) then product should be coming out.
This all works fine and is quite effective.
The problem we have is that when the operator changes the speed setting we have to come along with the laptop and change the trigger bit manually. I want to use a relatively cheap HMI(I am looking at the E150) so that the operator can do this themselves.
The problem I am having is how to convert the value from the HMI to the trigger bit. ie user inputs 60 into a data register how do I get it to look at M60.
Mike
Mike
