Adjust Pen Caption Order in FT View SE
dmong
Sep 2022
Warren, PA
Hello all! This is probably a silly question but, hey, I can't figure it out. Is there a way to adjust the order that the pens are displayed under the captions in a FactoryTalk View SE trend? I added a new pen and it put it at the bottom of the pen list, which I think is the only option. I would like to adjust the order of the captions so this new pen is the 5th one of 10 pens. The only way I can see to do it is delete all the pens and relist them in the order I want them in. This surely can't be the only way is it?
Welcome to the forum!
Unfortunately, yes, that's the only way to do it. Welcome to FactoryTalk View 🔨
Thanks for the quick response ASF. Unfortunately I have been working with FTView for many years, its just not my primary job anymore and I've gotten rusty to say the least. The more I remember the more I wish I could forget!
Hello Gents, I have got a request to stop the system at fixed times through the day (at End of Day/Night shifts) which could be done using the...
941
Hello guys, I use Tia Portal V16. What is the best way to change the indexed HMI tags when I change the format of an Udt in my plc program...
1,313
Good Evening , After running for 2 years , I have a few Powerflex 525 drives faulting out with a F 73 Ethernet Fault . What have you guys...
2,597
Hi all I thought I had this working but upon doing a checkup a few months after the machine was commissioned, I found that adjusting the RTC via...
1,873
We have a process where we heat parts based on a pre set time variable. After that we bring a servo down with a touch probe to measure the parts...
1,615
