Adjusting mouse sensitivity on Mitsubishi E1101
Damiac
Aug 2009
MA
We have a mitsubishi e1101 touch screen that is going into a hazardous environment, so we are using an industrial explosion proof mouse. It has a serial cable, which we are putting through a serial-usb converter into the usb slot of the HMI. The mouse does function, however it is much too sensitive. I am trying to find a way to lower the sensitivity of the mouse. I know the E1101 runs windows CE, so it seems like i should be able to get into the mouse settings, but so far I haven't had any luck.
Anyone have any ideas?
The mouse we are using is a Durapoint OEM Mouse. It has three jumper settings, fast, medium, and slow(default). The slow jumper is still intact, but it is much too fast.
BryanG is right. I've worked with the E series touch screens from the E50 to the E910 and the people at Beijer are very helpful and have helped us solve several problems over the last 6 - 7 years.
Hello, I am using a vpn to connect a compact logix controller with a 1734-aent. I can see both in linx but there is a connection issue when I try...
2,529
Is there any way to increase the communication timeout value for devices in a FactoryTalk ME application? We have a communication path that...
1,156
I am displaying inch position values in numerous places on a Kadet G307K2. The display format is three decimal places, i.e. 00.000. I need to...
2,213
I have two questions: When you open the settings for the PID you have the option of doing manual and auto does manual use the values entered and...
1,756
Hello, I have a program that monitors pressure in a manifold discharge pipe. Pressure in the pipe should be less then 7.5 PSI. If the pressure is...
17
12,760
