Advantage to sinking inputs
PackagingRich
Jun 2009
Chicago
22
Hi all,
We are replacing a old SLC50/2 with a new MICROLOGIX 1220.
Old inputs were wired 24vdc sinking. Is there an advantage to this? Should I keep the same, just wondering.
The DC input controller can be wired either way. The advantage of the sinking 24VDC is that it is already wired that way. If it works then fine.
For new controls the switching input should switch the ungrounded conductor (if one is grounded) to avoid false turn on in the event of an accidental signal grounding.
1. If it was working before don't change it.
2. If new rules require that you implement grounding of the 24VDC supply then US common practice is to ground the negative side. Be sure to check all input and output devioces for any problems with this.
Ever use this instruction and what was your reason?
886
Hi! I use a s7-1200 with a HSC single phase on input i0.0 100kHz, and input filter set to lowest 0,1uS. It is around 1300pulses on each step we...
1,765
Hello, In our company, we are currently looking to change our way of programming since we've been growing for the last 10 year and our projects...
5,045
Hi All, Who can tell me what's the benifit to use isolated DI/DO module. Our customer spec 2 modules in a project: ALB1769IA8I ALB1769OW81...
5,873
Dear Experts, What is the advantage if FC5 is transferred to FC6 as DATA TYPE BLOCK_FC IN Parameter? Where do I find its application? Why do we...
4,347
