Advice on a smart relay
danw
Oct 2004
midwest, USA
3,427
Does a so-called "smart relay" have enough I/O and timer logic to do the tasks shown below? If so, I'm open to recommendations.
I'd prefer dry contact outputs (very low duty cycle, once day) but will live with solid state if need be.
why a smart "relay"?
an AD click is super cheap and also idec has some really cheap plc's. from what I can tell, cheaper than the zelio smart relay.
Another vote for a Click unless you need to make use of the tiny integrated display these usually have. In addition, if you have a relay failure, you can opt for a separate, replaceable I/O module.
IMHO, the best use of a well built programmable relay is in applications where several high current contacts are needed. Such as when a typical small, cheap PLC would need interposing relays to handle the loads.
I'm setting up a new smart wireless gateway to communicate with Rosemont wireless transmitters, This will interface with a AB CLX L73 Processor...
1,435
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
217
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
299
Connected Components Help Hi there everyone, I’m recently new to the PLC world and was hoping somebody might steer me in the right...
440
