Advise on learning Siemens plcs
DmarkH
Jun 2012
Belfast
Hi
I am looking some advise on where to start learning about Siemens s5+s7 (monitoring,programming and fault finding)
My only plc experience is mitsubishi melsec and old toshiba provisor.
I have no experience of Siemens but have access to s5 + s7.
Thanks in advance
Ok, Iv got a s5 plc connected to a power supply and I/o module connected. The plc run light is coming on and looks like its working. When I connect to the laptop I am unsure how to acces the programme, file-new project? The plc is somatic s5 100u. Can any one advise on using the software, thanks
Hi
I may have to check again tomorrow, I didnt even realise there was different types. I think one programme was S5DOS and the other one was possible called P7 which appered to do S5+7. Although Im not sure as Im at home now I will have to check tomorrow.
I have been looking for manuals but cant seem to find anything for just getting started
S5DOS sounds like original Siemens Step5 programming software, a DOS program. might be hard to get along with, but would check that out first. Third party programs (although windows based) are not compatible with everything.
And manuals are to be found at Siemens's support site. or google for that matter. But don't expect to find a "S5 for dummy's" anywhere you'll have to put some effort into it.
Where are you in Belfast?
I am working in Belfast this week, maybe meet up and I could give you a few pointers?
S5DOS was the environment on top of CP/M for loading STEP5 and the COM software packages. It will work on a very old Simatic PC such as a PG635. Really only recommended for masochists !
Another guess is that it is maybe "S5 for Windows" which also exist in a version "S7 for Windows". That programming software is from IBH Soft and is still being sold.
I wouldnt waste much time with S5. The most you need to know is how to get a program listing from an old STEP5 project, so that it can assist in converting to S7.
Thanks for the offer Liam but I am away this week. I have found a pg95 software and have got connected to plc with some help. Looks easier than dosstep5 software
To begin, before the Trolls pop out, I know you get your tools/test your tools/find the right tools. Thats great, but at this point Im on a...
5,242
Hi everyone, I'm having a problems with simatic s7-300 & sinamics s120 system. Some error code are being appeared,Now how can I fix these error...
2,471
hello all... recently management level inculd my manager had ask me to do a task . where by currently we have small mixing plant (feedmill) where...
8,025
Hey all, I have a question for all you independent contractors. I have a client I agreed to work for them for a low rate with the idea that it...
2,437
:site: hello all.. i m need some advise for my upcoming project(work).. i been ask to develop a program from small size of mixing(batching...
2,529
