Aftermarket 1747-UIC problem
wolf3000
Dec 2010
Hawley, PA
I purchased an aftermarket 1747-UIC and it works great when plugged directly into an SLC500 processor or connected to the trunk line of a DH-485 network. I can't seem to get it to work when connected to the peripheral port of a 1747-AIC link coupler as described in A/B 1747-AIC instructions. I have experimented with swapping the Tx and Rx leads between the peripheral port and the UIC as well as the trunk line feeding the AIC but nothing I tried has worked. Does anybody know of a fix for this problem??
I was wondering if anyone knew of an aftermarket option for a 1784-U2DHP, or more specifically with going online with an slc5/04 that the rs232...
3,551
Hi all, Do any of you have a good source for servo power/feedback cables? I have an AB motor and drive that I need to connect. AB wants almost...
1,308
I have an application requiring me to integrate a CTC Interact Touchscreen (via ethernet) to a Siemens S7-300/S7-400 class PLC. Normally our CTC...
5,766
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
96
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
553
