Hi, All. I met a problem when I do the test for a control cabinet. It is when I test the AI module(1769-IF8).
My site signal is 4~20mA, which comes from a LED indicator. The indicator is already powered through power supply cable. As indicated in the manual, I wire the 4~20mA input terminal to the "I in +" and "V/I In -" terminal of the AI module.
After that, I use the AO module(1769-OF8C) to generate a 4~20mA signal and connect it to the AI input terminal. Then monitor the raw value form RSlogix5000. The reading is steady with a +-0.25% error.
Then I use a signal generator to generate a 4~20mA signal and wire it to the 4~20mA signal terminal. Strange thing happens. The reading still has an error, but the reading is unsteady , it shakes from -0.4%~+0.4%.
Did I make some mistake when wiring? Or what the difference between a 4~20mA signal generated from AO module and a signal from the signal generator?
Has anybody met such condition?
Any suggestion is welcomed.
Thanks in advance!!!
