AI wiring practices no. of cores
spaderkung
Aug 2007
South Sweden
389
Hi, I would appreciate some feedback on the number of cores used for the specific example of a 4-wire analog device, powered from the control system, using AO and DO from the transmitter. Basic question I guess, but this time I do not copy paste the el. dwg.
This is a small system. We do not have dedicated fuses for inputs / outputs.
The lowest core number I can think of is as below. Smaller cable, reduced no. of terminals.
PLC . . . . . Transmitter
Common 24V. . Supply power, +24 for AO, + 24 for DO
Supply 0V . . Supply power
Gnd . . . . . Gnd
Flow AI . . . AO
Volume DI . . DO
I think the power should be separated cores, mostly for the case to use a separate cable altogether if the transmitter becomes AC-powered.
What about jumpering the 24V for AO and DO inside the transmitter housing? Is it cheap and a separate core to be used instead? I think not, because if transmitter configured as Active, then it would not have separate + for these I imagine.
So I have this existing design. No, I did not design it. There are three identical machines controlled by 1 PLC. So there is the Main Control...
32
8,912
Can anyone advise on correct segregation of wiring/tubing..I am installing older process system with PLC-5 system that uses penumatic tubing...
2,831
I have a situation where the encoder cable to a drive is not long enough. Is it okay to run this through a terminal block? Should it be a...
2,878
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
125
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
82
