AIN/AEX Help
dd40001
Jun 2008
Corvallis
Hello, I am very new with PLCs. I am working with a autmation direct dl06. I am working on a project to recieve barcodes from a Metrolgoc MK7210. I have it wired right and have checked to make sure I have the right input from hyper terminal. I am having trouble getting the values to go into vmem of the plc. I am trying to code it using the memory example in the back of the book(http://www.geocities.com/dd40001/image.JPG). I am watching the status and nothing is changing.
I have the port settings in non-sequence, I don't know if this will make a difference or not.
Any help is very greatly appreciated
Also this is my AIN configuration
Port Number:K2
Data Destination:V2000
Interchar Timeout: 500 ms
First Char Timeout: 2000 ms
Byte Swap: All but Null
Termination Code(s): 0D
Overflow Error:C4
Busy C0
Complete:C1
Interchar. Timeout Error:C2
First Char Timeout Error: C3
357
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
143
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
107
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
203
and then when i open the windowmaker, intouch is shutdown... that's not work that's demo I have 30days demo
201
