Allen Bradley 1336 Impact Drive
badmancan
Jan 2021
Cluj-Napoca
Hello,
I am trying to run an encoderless motor with my Allen Bradley 1336 Impact Drive but I cannot get past the Vel Fdbk Loss F5048 error, even when I change parameter 150 to Encoderless.
Anyone with a little bit of experience using these drives?
Those drives prefer you to set that via the quick start and then running the autotune settings.
Edit: Also, isn't p64 the motor feedback setting? 150 is what.. data in?
Good Morning , I have a customer that lost a Allen Bradley 1336 Impact drive last night. Allen Bradley does not build this drive anymore ...
3,725
Does anyone know if its possible to "reset" or "change" the password of an old Allen Bradley "1336 PLUS" VFD without knowing the current pasword?
8,276
I am trying to set up one of these drives on a high speed test cell where the max speed is 14900rpm. Parameters 40 and 41 (Rev Speed Limit and...
4,782
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
93
416
