Allen-bradley ATA 32Mb flash memory card
davidtanwei
Jul 2007
spain
Recently, i purchased one memory card for my back-up purposes.
With this new card, i got no problem backup my program on PV600 touchscreen/PV900touchscreen. I havent backup for my PV1000touchscreen yet untill i found this website. The reason is that i cant found the PV config.
Nevertheless, having search and read through. I will tried to reboot the PV1000 and take note of the bottom right square box. Press and never let go untill the config box came out. I will tried
that somewhere in the next 6hours time.
My main question is when i went to backup my PV550. I press the left and right arrow keys. It is able to bring me into the config box. However, once i slot in my memory card. It says unformatted card. I read one similar case where they conclude its not compatible. Will it work or wonth a try if i:
a) formatted the card. Assume no fault occurs and it does allow me to format. I can then backup pv550 first and then follow by the other toychscreen.???????
b) Since i already got the backup program on my desktop. I just burn the file into the card. Hopefully, it can then be able to read.???????
regards
david
Hi everyone, I have a small project where I need to use plc to get sensor data and log them to an sql server locally or remote. I have found...
2,815
Hello guys, I should communicate an L33ERM with firmware 30 with L35E with firmware 19. The idea is not to modify the firmware, because in L35E...
1,541
Hi, I am working on a project in Digi Module ConnectME9210 and sending data to Allen Bradley PLC (CompactLogix 5370 family). I am not sure which...
3,994
Hello guys, I am new to allen bradley systems, and I have question about access to M0 and M1 data file. I have SLC 5/03 processor, with prosoft...
3,064
Dear friends, I need to access the data of various energy meters connected to Allen Bradley PLC. My general approach to access data from any...
2,421
