Allen Bradley BASIC Modules
Some 1771-DB application run program located in RAM and program (or sub) located in EEPROM.
Check if the EEprom is installed in the socket.
If yes, you'll have also to back up the EPROM located program(s).
Ah right, ok. i will check that. we are running 1746-BAS-5/02.
Away from the backup topic, if we are using these to run C code which is the drivers for communicating to the Eurotherm units, is there any alternative? due to the fact that backing up is potentially dangerous (from a factory point of view) is there any alternatives to these units? Or anything that can do the same thing. We are looking into replacing the entire system and putting in a new installation that uses PID control within the PLC.
Any ideas, thoughts or musings on the topic would be very much appreciated.
Cheers
Cheers
Firstly, I'm not sure how a compiled executable can be incorporated into the BASIC module, but perhaps it can.
What Eurotherm modules are you trying to communicate with? What Protocol? They used to use a protocol called EIBISYNC, but newer devices have dropped that in favor of MODBUS. The BISYNC would need a custom driver, but it's not all that hard, and I think I have some old OS-9 C Source code around (oddly, for the 1771-DMC CoProcessor) that I wrote years and years ago you could have a look at.
For alternatives, I'd say head on over to ProSoft and take a look at their array of both protocol-dedicated, as well as C, ASM, BASIC, and other fully programmable communications interface modules for all AB (And many other) Platforms.
I have 2 identical systems that have the AB SLC500 Basic card in them. I system stopped working and the issue was traced back to the card...
3,050
Hello, Here we have the mentionned PLC which had, in the beginning, a serial line printer connected to one of the serial port of the basic module...
3,801
I have a simple question to someone that has experience with Allen Bradley 1771-db Basic Module Battery. My question is can I replace the battery...
5,057
X
Hello, Does anyone knows where i can find one program called PBASE to program the 1746-BAS Card from Allen Bradley?? I need to use both serial...
19
21,392
Hello, I want to program and testing a basic program for the Allen Bradley Basic module 1771-db series b. Is there anyone who has the Basic...
7,887
