Allen Bradley Basic Card
jstolaruk said:
By "command line mode" I mean the BAS's command line mode. To get to the command line mode I had to have already been connected.
At 1200 baud, big programs take a while to download/upload and especially when downloading because there is a delay after each program line while the BAS module evalulates the program line statement for errors and probably some intermediate P-code compling.
j, I am not trying to debate, just made a comment that I thought was relevant.
I understand what you were saying as AFTER I CONNECT I use the command line to CHANGE the default settings to 19200 baud etc...YOU did not say that clearly though.
QBasic is what is used to cut my teeth on. It is still available online for free. Use it to build and edit your program then download with HyperTerminal.
It's a long time since I programmed one but I believe there is a link on the board to put it into program mode then use standard basic commands like break run list etc. I tried the AB basic & found it expensive at the time & not that good so used a terminal emulator
I have 2 identical systems that have the AB SLC500 Basic card in them. I system stopped working and the issue was traced back to the card...
3,047
Hello, Here we have the mentionned PLC which had, in the beginning, a serial line printer connected to one of the serial port of the basic module...
3,799
I have a simple question to someone that has experience with Allen Bradley 1771-db Basic Module Battery. My question is can I replace the battery...
5,055
Hi all, I have been given the task of surveying all of the 'BASIC' modules that we are using around the factory. The only problem is...i dont...
18
4,921
Hello, I want to program and testing a basic program for the Allen Bradley Basic module 1771-db series b. Is there anyone who has the Basic...
7,885
