Goodknight436
Hey Guys
I have a Micrologix 1400 that has Analog output card 1762-OF4. I need the analog output card to send a signal to a receiver (I am using ahttp://www.sensaphone.com/pdf/LIT-0171_v1.5_WEB.pdf). However no matter how I hook it up the the Analog output blows up on me. I have gone through three of these and is starting to get real expensive fast. So can someone tell me how to properly wire this thing up?
*I have tried this so far in descending order.
*Note Transmitter has non isolated common
*Note Receiver has non isolated common
(#P#) = DC Power Supply
(#T#) = Transmitter
(#R#) = Receiver
Combination 1: (#T+)(+R-)(-T#)
*After it blew I found transmitter was configure for a Thermocouple so I thought the resistance blew it so I switch it to 4-20ma for the next try.
Combination 2: (#T+)(+R-)(-T#)
*From my understanding the transmitter sends out a 24VDC signal and has a max current of 132ma so thought I be able to power all 3 analog signals without a DC power supply in series.
Combination 3: (#P+)(-T+)(+R-)(-P#)
*I set it up that way as it was the recommendation from the Receivers Technical support. I had to reverse the Transmitter Polarity because both transmitter and receiver are non isolated.
Any help would appreciated Thanks Goodknight436
(#T#) = Transmitter
(#R#) = Receiver
