Allen Bradley Internal Bits
chrisj91
Nov 2010
England
33
Hi, just wondering if anyone could help me out with an internal reference . . . ??
I'm using a Micrologix 1500 LRP, and it has a BAT. LO LED indicating when the battery is running out and would like to know the internal bit reference for this so I could code it to energize an output which will display a warning in the HMI.
As always, any help would be greatly appreciated . . .
Wow, thanks Mickey, exactly what I was looking for . . . !!
I had tried searching their documents, but I guess I didn't do it very well :oops:
RhRwlNBHUh2PDAIQkiSTwdNXXrw4MiNHG5mhNKohC1boAYDAgAh+QQFKACoACwIAAgADwAKAAAIZgAxoBpIsODAC6gEGjTIAiGCAwsJIpjAqFGIAwECFMx4IASNSKhYYMCYseQBBA0noQJFaWTJACcpxQA5MMaEEBgQYAgRAlWMSosKXqAxgQXBC5GCLmR04QKjSpMaRRyIadGiUQsDAgA7
I would think that you would need some kind of code.
Once that S:5/11 bit goes on, it probably won't go off until you change the battery.
If you acknowledge the alarm, how will you ever see it again?
Thanks for that Alaric, I was thinking the same in my head after I posted the OP . . . And we use FactoryTalk which is AB's own HMI anyways so it should definitely work . . . !!
And gbradley, I see what you're saying, but I don't really want them to be able to acknowledge or reset it anyway until the battery is changed, that way the won't forget to do so ;)
And even if they do acknowledge it, it will stay in the alarm banner until the battery has been changed anyway because the bit will remain a 1 as you said.
Thanks guys, all your help is appreciated :)
Good Afternoon , We have a number of these Allen Bradley GuardMaster Safety Relays in the plant. We had a problem with a safety circuit...
1,971
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
77
413
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
111
19
776
