Allen Bradley PV "Version Incompatibility"
Burch
Jun 2014
Michigan
54
I'm attempting to install a new application in a PV1000.
Getting a message, ERROR: Cannot open project due to version incompatibility.
I'm guessing I need a firmware update?
Thanks,
Burch
Is this a PanelView Standard (2711) or a PanelView Plus (2711P) ?
I general, yes, you probably need a firmware upgrade for the terminal.
Do you know what firmware revision the terminal is running currently ?
I'm sorry its a PanelView Plus
One last question, I did a little digging, and can not seem to find the current firmware installed. My memory has failed, because I though there was a way to check?
Thanks again,
Burch
I don't have a terminal in front of me to check, but I think it's in the configuration menus under Terminal Settings, maybe "FactoryTalk View ME Station" settings.
In general, a newer PV+ can run an older *.MER runtime.
So if you have access to the FactoryTalk View Studio software, just create a Runtime with the appropriate firmware to match the terminal, or older.
If you don't have access to the FactoryTalk View Studio software, you'll have to try to figure out which revision it was created with, and upgrade the terminal to match. This opens up the can of worms about the difference between the PV+ and the PV+6 hardware.
There was a thread a couple of weeks ago about how to determine the "version created with" for a FactorTalk View ME runtime file. I didn't follow it but it might be helpful to you.
So the basic task is to figure out exactly what you've got: look at the exact part number and the sticker on the terminal to figure out which version it was shipped with, at least.
If you have access to the configuration menu, then go to...
Terminal Settings -> System Information -> About RSView/FactoryTalk ME Station.
I would flash the terminal to the firmware of your new application, but you could alternatively save your new application as an older version compatible with the current firmware on the terminal.
This terminal can be flashed to version 5.10 max. So if your new app is higher than that you'll have to use plan B above.
Regards,
George
I think this is the thread you're referring to, Ken:
http://www.plctalk.net/qanda/showthread.php?t=90313
In it, dmroeder posts a link to a vb app he created that can tell the "created in" version of FT View ME mer and apa files, as well as RSLogix5000 and Autocad files. Pretty handy tool. V1.2 i think was the latest rev he had up.
Hello everyone, Is there a free version of Rockwell's programming software for Allen Bradley plc's? It's been a lot of years since I worked with...
5,131
Hello Experts, I hope everyone is safe and healthy!! Below mentioned Siemens code is in STL i have to write it in Structure text in Allen...
1,667
Good day can anyone tell me the name of the program to convert a ab 2711 panelview program from a older firmware to a newer firmware, like a...
3,151
Can anyone please give assistance, I have 2 project sites both with different CPU versions, the one site runs with version 13, the other with...
9,467
I have plans for some new equipment. The plans call for a Modicon M340 with a BMX CPS 2000 and BMX P34 2030. My plant contains only...
3,145
