Allen Bradley read data of sensors
Snipy
Jul 2012
paris
16
Hey,
This thread is for a new problem,
I complete a project (a little factory with conveyors, sensors and robots) and I must use a PLC, the Allen Bradley CompactLogix L32E plc.
Before I have never used a plc, so it's my first time.
To begin, I create a project with the software RSLogix 5000, I configured and established a serial connection (with RSLinx CLassic) and after I configured my first output module : a 1769-OW8I (ac/dc output).
To begin my program is easy just a "output energize" for the data : (Local:1:O.Data.2) .
Now I would like read the data from the sensor :
Visolux RL29-8-2000
datasheet : http://www.mrk.eu/prell/KATALOG OPTO STANDARD tdoct0219a_eng.pdf
The output of sensor is either 24V or 0V. And when there is 24V, I want to run an output (Local:1:O.Data.2) (to lunch the robot).
I have available an analog module 1769-IF4XOF2 and an AC digital input module 1769-IA16 (datasheet : http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1769-in006_-en-p.pdf).
I think it's not possible to use the digital input because it's AC no ?
QUESTION : If I want to use this module, I just connect the source in IN0 ?
What is the best way to success to read my sensor?
Thank you very much for your help !
You need a DC digital input module for this sensoro_O
Something like a 1769-IQ16
Well, it has to be an interface relay..
Not any relay will do...
Sorry, I am being a little bit mischievous..
Look, do you remember this post from a forum regular
Snipy,
These are very,very basic electrical questions. I strongly recommend you get some help from someone with electrical knowledge.
I admire your efforts in learning from this site, BUT, you are now in the area of where "Ouch, it bites" - you are dealing with 120VAC - you need to be trained properly.
Do you think that I could learn to be a doctor, dentist or candlestick maker from reading stuff on the internet?
PLC is ControlLogix 1756-L73 CPU with firmware 28 In the PLC the value for A60[110] is "AT", Style ASCII, Data Type INT. In KEPServerEX I tried...
1,577
Hi All, I wonder if anyone knows the answer, or even if its a stupid question, as to whether the ALMA / ALMD blocks that rslogix uses for alarms...
6,308
Hello all Seems I am in a strange situation at work. I myself am very familiar with PLC's and the kind I prefer are Koyo or Automation...
3,116
Hi all, Working scenario is, My HMI project is having two integer tags at address N7:0 and N7:1. In this case i know i can make only one read...
3,457
my question is: I attach a weight to a PLC SLC 5 / 03 to the rs232 port to read ascii I read in the string 82 \ A0 \ A0 \ A0 \ A0 \ B4 \ B75 \...
4,338
