Allen Bradley to Siemens
DJ Wall
Dec 2004
I am trying to switch a previously developed elevator which is controlled using Allen Bradley to Siemens and I do not want to rewire the entire elevator. There is a piece of harware out there that i can use to convert compact logic to Profibus if anyone knows what this is it would be greatly appreciated.
The worlds of AB and Siemens stubbornly refuses to meet.
Is it like this ? :
You have CompactLogix rack(s) that you want to connect via Profibus.
There is no Profibus card that you can plug straight onto the CompactLogix hardware.
The closest you can get is to find some Profibus capable hardware that has the same "form factor" as the Compactlogix. Exchanging all the CompactLogix hardware with this "other" hardware, You then have to reconnect the i/o to the new hardware (and hope that the wires are long enough !).
It could be Siemens ET200M (A Profibus adapter 6ES7 153-1AA03-0XB0 + S7-300 i/o modules). This is the closest physical form to the CompactLogix that I can think of.
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
657
Good morning all, I've got a customer in a bind. They, like many, got confused about Allen Bradley's EtherNet/IP protocol and assumed it was...
2,652
hi guys I have allen Bradley software on a laptop , and would like to but siemens tia portal and classic on the same laptop ? is there still...
1,365
Hello Experts, I hope everyone is safe and healthy!! Below mentioned Siemens code is in STL i have to write it in Structure text in Allen...
1,656
