Allen Bradlly PLC
salah
Jul 2003
Benghazi/Libya
22
Hello All members,
I am using AB SLC500 PLC, Processor Model 1747-L532. Could you please provide me information on hardware and programming of this type of processor.
When I installed the system at first time the processor front panel indication "FLT" shows Flahing LED. What this mean and where can I found the diagnostic and troubleshooting procedure in order to solve the problem and put the system in RUN mode.
If any one have information about web sites which help to obtain hardware and software manuals about this type of PLC please let me know.
Thanks alot for your help
Salah
One of the most common reasons for a flashing FLT light is that the processor simply has no program installed. If this is the case it is up to you, after learning about this unit and obtaining the proper software and cables, to write a simple program, downloading it then placing the PLC in 'run'.
Hi ! Grettings of day , can anybudy suggest me how to comunicate Allen Bradlly power flex drive ? which software it requred and is it free or paid...
2,036
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
147
421
