Alspa 80-75...GE Fanuc Series 90-70 doc/info
Ralf_GER
Dec 2015
north
Hi everybody greetings from Germany,
i am looking for some informations about GE Plc´s. We have a vessel equiped with a Network of such PLC´s. I have no documetation about, never saw such pls´s before all i have is the Hardware and an old Laptop wich running Alspa 80-75 programming Software Version 7.02 direct Serial com. Also from that Software i have no Manual. The System Layout is:
PSU 697 PWR 713
CPU 697 CPU 781
FIP Bus Controller BEM 741
Digital I/P MDL 653
Sparc 5 TE Sbus front Panel
2 of that stations are connected to 6 outstations with
ic 693 pwr 330
ic 693 cpu 351
ic 693 bem 340
ic 693 mdl 655
ic 693 mdl 752
ic 693 alg 220
he 693 dac 410
ic 693 chs 391
what i want is ...understanding the card´s function, understand how the plc´s communicate...read out the programms to find out how they work. i have experience with siemens plc´s type s5 and s7 used allmost function block or awl.
is there any site where i can get Manuals of the hard and Software maybe programming guide and or operaion table ?
Best regards
ralf
PSU 697 PWR 713
CPU 697 CPU 781
Digital I/P MDL 653
ic 693 pwr 330
ic 693 cpu 351
ic 693 bem 340
ic 693 mdl 655
ic 693 mdl 752
ic 693 alg 220
he 693 dac 410
ic 693 chs 391
Best regards
ralf
You should be able to communicate to the GE Fanuc branded PLCs using Proficy Machine Edition Software from GE Automation & Control:
http://support.ge-ip.com/support/index?page=spage&id=ST6&locale=en-US&locale=en_US
The manuals can be downloaded from the GE support web site, same link as above but under Technical Documentation. from there search for the hardware part number you need.
I thought the alspa C90-70 was a re- branded GE 90-70 by cegelec
FIP is for Factory Information Protocol
I think that the remote stations are C90-30's which is the GE 90-30 series
Sorry I do not have access to the software or manuals
I received a email from a customer looking to support their Alstom Alspa PLC's I think GE bought them, my customer is wondering.... Guessing I...
2,253
Hi, Do you have any guide on how to convert Alspa C80-35 logic program to RSLogix 5000? Thank you.
1,156
Hi everyone, Do anyone had worked on before Alspa 1032 or any alspa drives?..Anyone know about break wire motor fault on this drive?
1,389
Hello, i have an Problem with one plc... suddently the CPU stopped and we were not able to start it again. Restart by switching on/off didnt...
3,203
We are trying to find a way of loading a P8 program from a PLC into P80 without losing the variable names. We can load the program from the PLC...
2,020
