Alternatives to PCI KT Card for DH+ coms on Win7
Mar 2009
Leeds
49
We are upgrading a Wonderware Intouch 7.0 SCADA system to Intouch 2014 R2.
The current system runs on NT4 and uses wonderwares AB1748KT IO driver with a PCI KT card to talk to a PLC5/30 and a SLC500.
We need to find a replacement for the KT card for DH+ coms and a new IO driver/server. The new machine is an IPC running Windows 7 Untimate 32bit and has already been purchased but has no PCI or even PCIe so we limited to either USB or Ethernet.
I was considering using ABs 1784-U2DHP USB to Data Highway Plus Interface with kepserver but looking more into this its DF1 to DH+ and we are worried about bottle necks in the com's and update speeds.
So I'm now looking at Ethernet to DH+ bridges.
Has any one used the following product EQ7000 and have any comments.
http://www.equustek.com/eq7000-ethernet-ip-to-dh-gateway/
I was considering using ABs 1784-U2DHP USB to Data Highway Plus Interface with kepserver but looking more into this its DF1 to DH+ and are worried about bottle necks in the com's and update speeds.
Do not worry about this. The performance is similar to a PKTX card.
One issue with the U2DHP is that its interface is an 8-pin mini-DIN. So it has to be nearby a PLC5 or SLC5/04 to transition to the blue cable. That, or you manufacture your own adapter from 8-pin mini-DIN to 3-pin Phoenix connector (if someone knows of a commercially available adapter I would like to know).
I did this cable to get to terminal block. Don't supose any one has the pinouts to make this cable up.
http://www.ebay.co.uk/itm/Allen-Bra...755?pt=LH_DefaultDomain_0&hash=item417151ed13
The DASABCIP is a very stable way of communicating DH+
to the SLC's and PLC-5's with Wonderware. Just remember
to add your access name to your device groups in the
DA server for your tags in WW.
We have a critical alarm system that uses Win-911 paging software that talks to an annunciator panel using a Modbus driver. The software runs on...
548
Greetings! I have used IFM IO-Link devices for a while now from IFM and they have worked out very well. Unfortunately, IFM is among the many...
2,385
I’ve recently been given several IB-32 and OB32 digital cards for an AB SLC500 that use the 32 pin plugs to a breakout board of some sort...
695
Hello, Does anyone have suggestions for an alternative to the AB 1783-NATR router? I need something in similar physical size but hoping to find...
3,844
I have an older Panelview 1000 that I wanted to replace with a PV Plus 7, however the prices for one of these is becoming quite high. I have...
26
10,914
