An Alternative to Panelview
tjoneill
Jul 2007
Michigan
66
Hello all,
I am just looking around for an alternative to the expensive
Panelview terminals and thought I would ask the experts for your opinions and what you use.
Most of our plc's are slc,micrologix and contrologix with DH485,DH+ and ethernet.
Thanks for your thoughts
Tim
Redlion G3 series will do dh485 and ethernet, wont do dh+ without some sort of convertor.
Good price, excellent product and tech support second to none.
They are regulars on this forum board as well.
I try not to use anything else now.
Hello all,
Tim
Parker CTC Xpress will work with your AB hardware.
6', 8', 10' HMIs.
It does come with all the drivers preloaded you just have to configure it when setting up your comms and the application.
About 1/2 the price of a panelview.
We've used it with Micro, SLC, Compact and Control Logix hardware, no issues.
Last time I checked the c-more line wont work with the non-logix processors. Red lion would work with what you have listed and GE has an HMI that is priced well that will work also. We have vids on the Red Lion and will have some on the GE soon if you want to see how they configure.
Russell
FYI on the c-more
Checked out the link - Cool. I looked into the C-More years ago and thought it looked like a good product. It doesnt list a serial port in the specs. Does it have one built in or do you have to use a USB adapter?
Russell
We use C-more's on almost all of our panels now. Most of the time we use Ethernet, a 5 port switch allows us to set up a dedicated comm link between the PLC and the screen and any other devices in the panel, and also allows us to plug the laptop in and watch everything in "real" time without the pain of swapping cables around.
I find that cutting one big hole in a panel door sure beats laying out, punching a zillion holes, installing all the switches and then wiring all of them.
BTW we use the 15 inch ones...they look sharp...(y)
David
I'm looking for a cheaper HMI alternative that still can be integrated into a system using Rockwell PLCs. I've done a tad bit of research but I...
34
14,647
Looking to step away from the PVP hardware but not AB software. Its what customers request so thats just not usually an option. Wondering what...
3,273
I have a small project at home that I am wanting to integrate a PLC with. I picked up a PanelView Plus 400 off ebay with the intent of using it to...
4,509
OK I have been bitten by the service pac 3 bug that makes it impossible for me to use the AB PIC driver to communicate with my RS 232 port on my...
22
6,891
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
153
