An incremental rotary encoder example for Omron
I would suggest to you have a go yourself and then post what you have done here and all will help you.
The wires goes to the Inputs 3,4 and 5. A,B and Z. Then the value will be available @ 230+1. That's for starters. I'm not one to explain things very good but, ya, thats a begining. You also have to set the PLC up so that the High Speed Counter is enabled.
Welcome Boyko!
I have to agree with BobB on this. If you go to the Omron Knowledge Center, www.knowledge.omron.com and download the Programming Manual for the CPM2 Manual Number W353, Section 2-2 gives a very good explanation of the high speed counter function and setup for your plc.
You will need to enable the high speed counter function in the plc setup as mentioned in the other posts.
Take a shot at it, then post if you have any questions.
Hi, Everyone I am interfacing rotary encoder(incremental encoder) with PLC. This encoder using for speed measurement (RPM). The encoder is giving...
4,544
Hi guys! I know the Siemens S7-1200 has pulse inputs but I was wondering if you can connect a standard incremental encoder in quadrature mode...
4,021
Hi, I am working on a project to upgrade a control cabinet for assembly machine. We are thinking also to replace some CAM_SWITCHES with OMRON...
9,162
Hello, I am working with a omron E6C2-CWZ5B rotary encoder (differential phase A, B and Z, 360 P/R). I am having trouble with it finding degrees...
3,359
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
123
