an old bale openers machine
tulip
Oct 2005
ist
236
we will modifie a old bale opener machine and we use S7-300.There is a rail and A and B side of the cotton bales available.If the request came from the silo head is moving on the rail.and flapping cottons until the entered value on the HMI screen.One each magnet is placed on the start and end of the cotton bales.There is one switch in moving on the rail head and changing the position of a magnet retains its position until the other magnets.My question is (continuous requests while) how this moving head goes forward and comes back ?I could not understand,any idea,thanks for advance...
ttps://www.youtube.com/watch?v=d1uNZbIRRjc
It is showing machine.But we dont have sequence of events chart of machine.
Interesting video.
Based upon the following inputs:
Start, Stop, Magnet Sensor 1, magnet sensor 2
If you have the magnet sensor 1 and the start button is pressed then go forward. This would be a latched bit and memory retentive.
When the Magnet sensor 2 is activated it will stop reverse direction. This will continue until magnet sensor 1 is hit or stop is hit.
The next step would be to list all of the inputs and outputs of the machine.
Regards,
Garry
http://www.accautomation.ca
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
88
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
144
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
244
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
105
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
315
