analog address for input&output (SIMATIC 7)
MAHER
Jul 2007
CAIRO
82
HI
I wnat to know the address for analog input & output for ( SIMATIC 7),
and please any application for that .
THANKS FOR YOUR HELPING.
The module is setup in the hardware config for the address. Then you have PIW for analog in and PQW for analog out. You can put the PIW into a variable table but you can't the PQW.
Hello Maher;
Many posts on this forum have dealt with this issue. You can do a Search (at the top of the forum page) on "S7 analog" or something approaching, you should find a lot of information.
Here is one thread that dealt with integrated analog inputs on a S7-313C, recently:
http://www.plctalk.net/qanda/showthread.php?t=30356
Hope this helps,
Daniel Chartier
Hi
Thanks For You , You Add For Me Information About This Subgect.
But I Hopr You Have A Completed Application Which Contains The Following Points:
_ The Configuration For The Module ( Online Or Offline).
_ Addresses
_ The Idetification For Analog Input Signal (0 To 10 Volts) .
_ How Can I Make The Scalling?
see http://www.automation.siemens.com/simatic/portal/html_76/techdok_simatic/controller_techdoku.htm#1b
SIMATIC S7-300
Manuals for Analog modules
http://support.automation.siemens.com/WW/view/en/10867370
http://support.automation.siemens.com/WW/view/en/10805166/133300
and Help for FC105 "SCALE" C:\Siemens\Step7\S7BIN\S7RFBL2B.HLP
or F1 in selected FC
thank you very much sir
iam happy from your information which you added it for me , know ican configure the ( I &O )MODULES.PLEASE CAN YOU GET FOR ME ANY SITE TO ILLUSTRATE AND TO GET (PDF) FILE FOR SCALLING PROCESS ?
THANKS A LOT : MAHER
Hi Ekbist
Thanks For Your Information , Please Can You Get For Me Any (pdf) File To Clear For Me The Scalling Procedure I NEED APPLICATION ON IT .
Maher
I am new in PLC Programming. We have AB SLC 5/03 and RSLogix500 program. We have a new analog equipment that would be connected to Input Analog...
4,943
Hi I am making some programming changes to a machine for a client who is using an automation direct dl 06 PLC and ea9-6xx HMI. Ive added a new...
6,400
I can't find the addresses for the analog inputs anywhere. --- A642 and A643, figured it out --- Thanks!
1,278
Has anyone here worked with a Mitsubishi PLC with analog inputs and outputs? I'm kind of a newbie and haven't yet discovered how to do this...
4,192
Hello, New to Siemens step 7 series e.g S7-200,300 . Need to know from Siemens experts what are the standard addressing for Digital...
7,111
