Analog Ammeter for Outdoor
Levi G
Sep 2015
Alberta
148
Hi does anyone know of a Analog Ammeter for Outdoor.(The type with a dial.)
The one I'm looking for would require a 4-20mA input and a range from 0-100Amps.
I have talked with Crompton and they say they don't have one for Outdoor.
Thanks.
He may be thinking about temperature range also. Levi G you may want to list, at least for your own search efforts, the range of environmental factors under which the meter would have to operate.
Your best bet is probably to use a standard ammeter and mount it in a NEMA 4X enclosure with a clear cover like these: http://www.vynckier.com/multibox-sm...HvYBEZqkVC2suNsI30QZElZeMiwTvC9RoCUfMQAvD_BwE
Thanks Tom I will have a look at these.
bernie_carlton
I am looking to mount this outdoor in Canada so temperatures down to -40c, and weather like wind, snow, rain, hail and dust....and sun.
NEMA 4X, outdoor temperature rated
http://www.electro-meters.com/yokogawa/yokogawa-analog/270-series/?tab=2#TabbedPanels1
with some resistors you can make them suitable for 20 mA, however not for 4 mA but with the zero setting you will be able to make zero.
I saw somewhere in the text something about a feature with 20% zero offset for 4-20mA.
I'm guessing it's a long lead time for delivery though, whereas a digital read-out will be off-the-shelf.
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
33
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
121
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
134
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,177
283
