Analog comparator
imn
Aug 2005
NJ
Does anyone know where I can find an off the shelf solid state analog comparator board/module? It would compare a setpoint signal to a transducer input signal, 4-20mA, & output a 12/24 vdc digital signal when the transducer input exceeds the setpoint. This in turn is connected to a PLC high speed counter module. The application is response time testing of a solenoid valve shifting. It has to be high speed, < 1ms response time.
You might be in roll your own territory. I didn't do an exhaustive search but the few places I looked all had 100msec response or similar. You may be hard pressed to get an off-the-shelf solution with the speed you are looking for.
Keith
The LM319 fits the off-the-shelf solid state part of the request but falls a little short on the board/module requirement. :)
If I were faced with a similar challenge I would build up my own with a comparator like theDave2 is suggesting. It may not be an off the shelf module but it will certainly get the job done.
Keith
I am trying to help out a company who has no technical support and they are far away from my locale. We are trying to sense when a roll of paper...
1,451
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
39
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
129
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
143
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,213
