Analog encoder modules
2004sk4
May 2005
Georgia
172
Is there a company that makes a standalone module that would read rpms from a encoder and translate it to 0-10 volts. A dynapar digital speed controller (max spd jr4)will do it but i am looking for a lower cost alternative. It does not have to have a digital display. I am wanting to use something similiar to this to display rpms . A 1200r scan times will not make a accurate reading. The Display i am wanting is RPM using the analog input card with the above described module
thanks
http://omnicontrols.com/lists/newport3in.html
Give these guys a call to see if they can help you. I don't have enough information about the application. There are some really cheap ones (around $60) that will handle low frequency but no display. If you have time on your hands you can probably use a high speed counter or a servo card to work something out (providing you have some spare ones gathering dust).
i am needing to track the speed of 3 machines. The Best way i can see it to use something that in analog where i won't have a slowed scan time from a prox and a gear.
I am not to familier with the tach generator. The process run on a max of 3000 rpms
thanks
You can check Red-Lion $150 and Weidmuller $190 I used bout of them.
The Weidmuller is much easy to setup(5 min) and worth the different.
(if you would chose the Weidmuller just set the power off and on after the setup or do the setup when the power is off)
All the best
The company i work for uses ariba. By any chance would anyone know a supplier that would have this type of product.
thanks
Hello everyone. I'm new to the forum. I have a problem with the encoder and PID. We need to turn an encoder controlled rollover. I am using...
1,406
I'll set the scene a little before I explain the issue that I am having. I have an application where I have a Linear Servo Slide acting as a...
17
7,683
how to change a encoder pulse to analog out ? I would like to use a 1000 ppr encoder one shot the value every tenth second to scalable analog...
2,119
Hello dose anyone know how to configure the KL5111 from Beckhoff. see http://www.beckhoff.com/english.asp?bus_terminal/kl5111.htm particularly...
3,078
Has anyone interfaced an analog encoder to the analog inputs on a Micrologix 1100? I'm thinking about using an absolute single turn rotary encoder...
5,733
