Analog I/O's
Nilesh Sinha
Sep 2005
Ranchi
When considering analog I/O's, for what applications shud one consider differential I/O's, and what is the basic difference between the single ended analog input modules and differential input modules w.r.t application. Where can we consider single ended input modules.
1.
Signal noise and noise propagation.
With single ended I/O if you have noise on one channel the noise will affect all signals on the card through the common.
2. With single ended I/O modules you cannot mix power sources, with differential you can. So.... If you have a mixture of 2-wire and 4-wire devices, you cannot use single ended.
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
34
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
129
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
136
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,206
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
285
