Analog Inclinometer & Laser Measurement Sensor Display
jareds2020
Oct 2019
USA
Hello All,
I am fairly new to PLC's outside of the class, so apologies for any newbie communications.
I am trying to set up a system that will measure an angle change as well as a distance change, so I will be using two sensors: Inclinometer and Laser Distance Sensor.
I plan on using a Allen Bradley Micrologix 1100 (haven't looked into any others yet).
I would like to display the angle and distance for users, I have noticed the EVD111 from Electronic Displays, but would like to try something else since they seem a little large.
Is an HMI the only solution to display the angle and distance?
Thank you in advanced.
Sensors:
Inclinometer: B1N360V-Q42-CNX2-2H1150 - Turck Single Axis
Laser: Banner LTF12UC2LDQ
You can use basically any HMI to do that. There's ways to get info to be displayed on the 1100 LCD but not user friendly at all.
A lot of people may suggest Red Lion or Automation Direct for good bang for the buck HMI's.
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
116
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,143
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
259
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
