Analog Inputs Again
Jezz
Dec 2002
Kendal
399
Ok I got the fact that the 0 volts on my analog inputs are floating so I need some signal converters to sort out the signals now if I want to put on a mixture of 4-20mA and 0-10V inputs is that going to be ok.
+24V-----------------------------|
= 0.22 Cap |
4-20mA +-------> |Multiplexer
= 0.22 Cap |
0V------------------------------|
+10V-----------------------------|
= 0.22 Cap |
0-10V +-------> |Multiplexer
= 0.22 Cap |
Bit of a dodgy drawing I know but its the best I can do at work.
Jezz,
I have forgot what was the original problem. Could you summarize it for us?
It might have been easier to add on to the old thread...
Why a multiplexer? I have replaced them with straight analogue cards on several jobs for clients because they caused a lot of problems. May have been due to the brand of multiplexer - I do not know.
Sorry the multiplexer is in the analog card on the allen bradley (told you is was a bad drawing) I've now relised its always 0-10 V into the multiplexer as a 250 Ohm resistor is switched across the input when its set to run 4 - 20 mA .
So I think its ok now its been one of them jobs where if it can go wrong it will.
Can't wait till friday 11 Days Off :D :D :D
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
49
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
158
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
137
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
258
I have a SLC500 5/05 and we have an alarm setup to monitor the status of the Analog Inputs we have wired to a 1746-NI8. We are using 5 of the...
2,842
