analog output redundancy
Guest
Guest
G
I am using control logix 1756-OF8 analog output module for my application. I need to connect 2 analog output channels to a single field equipment(I/P converter) . Is there any external device to handle both channels(4-20 mA) and give one channel 4-20 mA output.
Hello everybody, I have a H_system including 2 CPU 400_H,3DI,1DO,1AO,1AI. Analog outputs are redundant. I used diode for redundancy purpose...
1,843
I am using control logix 1756-OF8 analog output module for my application. I need to connect 2 analog output channels to a single field...
5,753
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
331
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
90
Hi We're having issues with an FX1N-1DA-BD Analog output module. We're using an metallic contamination sensor MCS 1000 to detect particles. This...
114
