Analog output signal in 1v -5volt
praiserq
Oct 2020
Benin
Good day guys, am new here
Am using a 1765-Of8 analog output card to sent 0-5v signal for a remote setpoint to a temperature controller of 1-5v input signal. The output card signal type is both mA and volt with -10 to 10v range.
When I change the input type to volt and input the scaling of 0- 5v and 0-100 engineering unit. I read 20v in the output channel.
What am I not getting right?
All, This should be easy but I'm finding it difficult. I have an older OEM piece of equipment that I need to send a 0-5 vdc analog command...
1,935
Greetings, My company is working on a panel for an OEM and it is the first time we are using the Micro800 family - specifically the Micro850 with...
5,379
Hi, I am facing a problem. I want your help to sort out the problem. I am programming a PID temperature control loop in 9030 PLC. PID loop has...
23
25,750
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
319
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
