Analog PFC to HMI display via SLC500 SCP
LEO_1973
Jan 2015
Indiana
Hello all,
I'm having an issue displaying the value I'm getting from a PFC to display on my Red Lion G307..... and before anyone says it...I know I should have bought a Graphite with the analog card but it wasn't up to me so I'm stuck this time around.
Here's the set up, I have a Bimba PFC going to a Bimba control mod, from there it goes to an Allen Bradley Analog I/O card.
In my program, I'm using the SCP instruction to scale. My input in the program I:3.0 and the output is I:1.0, used to trigger a fail bit. This is all working correctly.
What I want to do is have the value of the milliamp output (the one I can view in the SCP instruction) also displayed on my HMI.
Can this be done?
Thanks!!
Got it....
Used a MOV command from my I:3.0 Source and made the Dest N7:1
From there I filled in the blanks on the tag properties and viola...
I used a simple square and put it behind the vertical scale using the newly created tag as the input.
This is not the best or perhaps the correct way to accomplish what I set out to do, but it works good for this application. The tag displays the value and there is a moving scale.
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
116
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,143
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
259
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
