Analog wiring help
titanspark76
Oct 2016
TN
42
I have done very little analog control and want to see if my understanding is correct on how to wire the device. I plan on using the following devices that I will link to at the bottom: AB 1734-IE4C analog card, AB 931S-B1C6D-DC signal conditioner and an Omega LCHD Load cell. Is this correct? Thank you in advance.
This is my thinking:
Connect 24VDC to the term 10 & 11 on the signal conditioner,
Terminal 1 to pins A&B of the Load Cell
Terminal 2 of the conditioner to pins C&D of the LoadCell
Terminal 4 of the conditioner to pin F of the Load cell
Terminal 5 of the conditioner to pin E of the Load cell
Terminal 7 of the Conditioner to IN0 of the IE4C
http://raise.rockwellautomation.com/raconfig/rtcache/pdf/931s-b1c6d-dc.pdf
https://www.omega.com/Manuals/manualpdf/M4086.pdf
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1734-in032_-en-p.pdf
Looks good to me..
24vdc + to terminal 10
24vdc - to terminal 11
The rest of the + and - wiring is shown on device wiring and in your post.
Hello, I am so confused now with the analog input module wiring. I am about to use a 9900 GF Signet transmitter for my analog input. I saw the...
5,480
Good Morning , I have a RTD , that I would like to wire into a 1756-IF8 Analog Input Card. Would you all a simple wiring diagram , of what...
1,211
Hi, i'm working with a differential pressure transmitter yokogawa EJA130E and have problems to connect it to a Schneider analog module TM3AI4...
2,075
Hello all, I'm trying the wire up a Baumer Inductive Conductivity/Temp combination sensor to a 1769 combo analog in/out module. The sensor is a...
22
4,529
So many of our tech support calls are due to faulty wiring. https://www.youtube.com/watch?v=pXcxkNt_1_8
1,605
