analogue control value (UK central heating system)
DLMUK
Jun 2013
Southampton
311
I have been looking around and cannot seem to find what I am after, hopefully someone here may have seen one.
It is for a little home project, I have an underfloor heating system which is controlled by a pump and a manual valve at the moment. The pipe work is 22mm.
What I would like to do is find a motorised valve with an analogue output which I can connect to a PLC/controller.
It needs to be 22mm input/output for water
240Vac/any DC input
mA or V output for signal processing.
I also want a thermometer to suit, what I have found so far is this:
Linky
Does anyone know of anything?
Thanks.
This stuff is probably not for those on a budget but we use a lot of Sauter stuff for Boiler/Steam/Water controls.
Works very good and last a long time.
I found a type of valve you may be interested in but you will need to find the correct controller to go with it on Sauters site or call a Sauter Rep in your area to work with you.
http://www.sauter-controls.com/en/products-sauter/product-details/pdm/vcl010032-2-way-control-valve-valveco.html
check out their entire site, they are bound to have what you need.
http://www.sauter-controls.com/en.html
BCS
I second Sauter :).
Use this actuator:
http://www.sauter-controls.com/pdm/docs/en_ds_en712323.pdf
eBay has some used ones listed, they are a little bit expensive, but worth the money imho.
@ boneless.
Yep thats the ones we have. (Well...I know that you know this already)(y)
@ OP
But they fit a different type of valve so just make sure you match the correct actuator to the correct valve.
The valve I posted above uses something more like this:
http://www.sauter-controls.com/pdm/docs/en_ds_en474894.pdf
But these seem to only work as position proportional, and would work from up/down, on/off signals from your thermostat or other controller.
If you can match a valve up to the controler boneless posted then those can be configured to run as True Analog or P.P.
On the Sauder home page I gave you link to you will see a full line of temperature control theromstats, also.
BCS
Hi, I have a project with several 1756-IF16 analogue input modules. I can use the modules channel fault bit to display a fault message on my...
2,645
369
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
93
I am using Mitsubishi PLC :FX3g and downloaded the program in it. When I connect Mitsubihi FX2N-4DA expansion module, it lost its communication...
267
Hi All, I am working on a small PLC system having Compact Logix LE33 PLC having only two IF4 card. Some of these channels are used for 4 - 20...
1,165
