Control Logix Analogue Input Module Faults
pr_wainwright
Jun 2011
Stockton on Tees
109
I have a project with several 1756-IF16 analogue input modules. I can use the modules channel fault bit to display a fault message on my HMI but I do not know what is classed as a fault? Would a short circuit or open circuit be detected on a channel and set the fault bit? I think open circuit would but I am unsure if short circuit would & don't fancy testing it. I have seen programmers check the scaled max and min values e.g. 4-20mA (3 or less would be open circuit & 21 or more would be short circuit) but I dont know if this is common practice.
Paul.
253
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
380
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
761
Possible for two processors in same rack to have separate motion groups across a single Kinetix Rack using a single EN3TR? One 6500/5700 rack, 8...
426
Hi all! I am hoping to find some help understanding the ABB VFD Connection to my Rockwell PLC. I have set up the VFD parameters based on...
670
