Reading MircoLogix bools & Ints to Control Logix?
des1234
Feb 2024
Ireland
hi all,
i have a plc i need to get info from for a site im working on:
I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im trying to read from to send bools and ints to my Control Logix PLC using the MSG Instruction which in the control logix I Select 'SLC Typed Read' to read from the Micro logix.
but Im having issues with the Communication Path as it doesn't seem to work
when i enter '2, PLC IP Address' it doesn't work but im able to see this PLC in rs link and go online to it but not able to able to make online edits though.
for reference i have another plc on the same network thats a micrologix 1100 and i can read from that fine using the same method outlined above.
any help on this would be gretly appreciated.
The path needs to reflect the path the message will take as it leaves the CLX controller. Can you please identify for us how your CLX and MicroLogix are connected as well as which CLX CPU you are using.
The MicroLogix 1100 has Ethernet built into it. Most ControlLogix do not and neither does the MicroLogix 1500. So how are they being connected?
OG
see attached Screenshot of the network in rs linx.
what im trying to do is setup the MSG instruction in the Control logix which i highlighted (Yellow) and what to read the Bools & int's from the Micrologix
highlighted (Green),
to do this in the controllogix msg instruction communication path i enter
2, 10.153.247.32 but this didn't work and got a communication error.
now im not sure if i need to use a different path but i tried other paths and had no luck with it.
Note: i blanked out PLC names as this is sensitive information.
145
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
100
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
233
Dear all, I don't know why setup of password became challenging and weird. After setting up the password and try to upload the ladder from the plc...
174
