Analogue signal monitoring
LO-LO
Jun 2007
Hong Kong
Dear Friends,
Now many types of PLC also have analogue input channels. If I want to monitor the profile (slope, level, duration etc) of the analogue signal after a state change of DI or DO signal, can a PLC do this? By what function?
Thank you.
LO-LO
Hi, in PLC if you want view the analogics values, you must programing a application on human machine interface (HMI)and make a connection with your PLC , and a other jobs.
If you are a new PLC user, download a documentation for your PLC and your HMI choice . good look
Almost all PLC manufacturers offer models that have analog inputs.
If the PLC can do math (almost all can), it can do this. The functions are basic math functions, + - * / > < =, and a timer instruction for duration.
Hi All, I am working on a small PLC system having Compact Logix LE33 PLC having only two IF4 card. Some of these channels are used for 4 - 20...
1,168
I have a TP070P delta PLC and I am trying to take an analogue input signal from a pressure sensor, all the tutorials online are suggesting to use...
1,082
Hello, I have a simple 3-wire 4-20mA pressure transmitter which I would like to split into two signals to send one to the devices interface and...
3,638
Hello, I a would like to create a rolling average for a flowmeter signal. I'm quite new to Siemens Step 7 - does anyone have a FB or can paste in...
8,998
Hi, was wondering if you could help. I am using a Micrologix 1200 PLC analogue card that measures back analogue input signals between 0-30mV. The...
2,830
