Any Old Omron Folks Around? C20
TAP62
Oct 2008
Ontario
I have an Omron C20 PLC in a shoe manufacturing machine. We lost the program but have purchased an Eprom from the original machine builder. We have followed the instructions and installed the Eprom on the board, set the dip switches correctly, but we still cannot get the program to load from the Eprom. Any Suggestions , I'm running out of soul.....
I dont see much option.
1.The EEProm is empty
2.Trun the power off take out programming console if you have,turn the power on again.
The PLC should load the program.
Last time I touch C** PLCs was 15 year ago.
I was looking in the book I didn't see any rezone.
Maybe the PLC damaged.
Since the original machine builder had an Eprom of the program, maybe he has a paper printout of the program that he could send you by fax or e-mail. If you get that I'm pretty sure you could get another PLC (different brand or newer model) and get the program re-written to get you going.
Not sure what "instructions" you are referring to, but
have you looked at the Omron W175 manual.
Sections 2-3 and 2-4 cover the Eprom install and dip switch setting information. You will need to know the memory size of the Eprom chip in order to properly set the jumper inside the processor.
Hope this will help.
Project involves updating a ~23 year old controller (C200HX CPU64). The HMI is a windows NT machine with the gui done with Delphi 5 (Pascal)...
1,119
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
2,018
Hello guys, Can someone advice what software do I need to open an old Omron CPU41 PLC project?
1,969
I am learning mnemonic code for a Omron Sysmac S6 PLC. Is my code below right to get it like the picture? 000 LD 0 001 AND 1 002 OR 2 003 OUT...
1,348
Hi, I've been asked what is involved to upgrade and old CQM1-21 Omron PLC to a CJ2M. I have the old file with an extension of .cdm and searches...
1,589
