Mnemonic coding for old Omron PLC
unsaint33
Sep 2019
MInnesota
118
I am learning mnemonic code for a Omron Sysmac S6 PLC. Is my code below right to get it like the picture?
000 LD 0
001 AND 1
002 OR 2
003 OUT ##
If I wanted contact-2 to branch around contact-0 and contact-1, how would I code differently?
welcome to the forum.
Do you have the manual for the S6?
I still have mine in the attic, saw it last week.
its been many years since I did an s6.
if I am not mistaken, your code could also be written as this.
Ld 0
LD 1
Or 2
And Ld
out xx
please be aware that there are variations in the firmware for the s6 and you need to be familiar with both types of programming.
in regards to your question.
Ld 0
And 1
Ld 2
Or LD
out xx
try both statemants out.
regards,
james
Blimey that takes me back a bit
I'm not sure that is right i agree that LD 0 AND 1 OR 2 AND LD out xx
but to or a contact around the two would be
LD 0
AND 1
OR 2
OUT xx
Well it's some time since my S6 and other omron but the above is correct for Mitsubish & Siemens, however siemens use brackets which makes more sense to me
Another STL question. In the attached screen shot the line with = #sf.S01_Dryer_ON dose not have the RLO on. But if we look lower in the logic...
1,228
Can you please verify my mnemonic code conversion? Thank you LD KR 2 AND 4 LD KR 0 OR 2 OUT 15
2,969
What ISA Mnemonic is commonly used for a setpoint? My ISA 2009 reference might be outdated. Since my Studio 5000 "Equipment Module" AOI is the...
2,433
I am working on an old TI315. I couldn't get the pc to communicate so I had to plug the programmer into the front of it and record the ladder...
2,778
Hi! Sinse beginning of my work whith Step7 I used Germany mnemonic. But in Help system is used English mnemonic. Maybe should me switch to English...
4,567
