CroCop said:I was going to write something, and started, but I erased it.
Simply: If you don't like AB pricing, don't buy it. But don't take every opportunity to let the forum hear about it.
Tark said:We should stop talking about AB and their high prices because, _________ .
A) it just goes without saying
B) we don’t want the secret to get out
C) I would rather put money in AB’s pocket than my own
D) they have to charge high prices in order to give free tech support
Ask for a little less starch in your shirts, don’t take everything so seriously, it’s not like we are talking about your first born. Or are we?
CroCop said:How about E?
E) Rockwell products are priced competitively enough to sell?
ckchew666 said:This is a broad question, I would say depends on customer, some customer just want a dirt cheap system, as long as it can work (stand alone & basic control).
Some will stated AB up front, & some system required higher spec (redundancy on CPU, network....etc...), no choice but to go for AB
I'm not sure other countries, but in Malaysia comparing apple to apple (siemens), AB CPU is expensive, IO modules are cheap. It's vice versa to Siemens.
patriot said:If the topic of this thread hurts your feelings, you need to get a life.
Terry Woods said:All I can say is... I've used, programmed, damned near every PLC-programming philosophy out there... including Ladder, STL, Grafcet (Stage), Forth, "C", and Assembly.
AND... I initially learned PLCs on AB... waaaay back when...
AND... All I can say, with regard to AB, is that it is clearly, CLEARLY, among the worst! Those AB-Engineers are nuts!
That includes AB's latest, ControlLogix-5000!
While I must admit that ControlLogix-5000 is one hell of a lot better than the earlier C_R_A_P... AB, including ControlLogix-5000, is still, in general, big-time C_R_A_P!!!!
If you ain't been around the block a time or two... should you be barking?
Terry Woods said:Crocop...
I'll have to put some time in to organize my gripes before I post them.
For the general viewing audience...
What's in your repertoire?
ckchew666 said:Hi,
I'm wondering if any of you guys knows if AB has a plan to manufacturer lower cost HMI? Something that would compare to Proface will be good.
I think the Proface HMI is much better than AB PanelView Standard, it should be compare with PV+. But the pricing wise Proface is much better. Furthermore their software is free also.
Thanks...please comment.
