ANY pointer repitition factor
SD_Scott
Feb 2006
South Carolina
176
I'm trying to view the number of bytes in an ANY pointer. If I have an array that consistes of DINT data, the number shows up as 1 byte. If I creat a UDT with one DINT and use that in an array it shows up correctly as 4 bytes.
L P##SourceData //Load ANY type pointer
LAR1 //Load it in AR1
L W [AR1,P#2.0] //Rep.factor
T #Length //Xfer to #Length
This array shows only 1 byte as the length of 1 DINT
Array_Of_Data ARRAY[0]
DINT
This shows 4 bytes as the length of 1 DINT
"Test_UDT_2"
The repetition count is the quantity of the type specified in the any pointer.
In your first example, there is 1 DINT
In your second example UDTs are always shown as a number of bytes
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
555
I am trying to access the value of a pointer via OPC UA in Codesys. I can share it directly and in a struct but I cant access the value of it when...
1,631
Why does my deconstruction of the input pointer only work with its own instance DB not inside the multi instance FB...See .doc The pointer at the...
2,390
Hi All, in many library function of TiaPortal some data must be write using the pointer format........ eg.: P#DB90.DBX0.0 WORD 10 is it...
2,823
I have a very strange issue and I cannot figure out why it is not working. I read input of type pointer and store it to local temp type any. I...
1,940
