Any tips for converting SLC program to DoMore?
gbeaker
Sep 2012
earth
148
I am in the process of converting a bunch of old SLC 5/03s to AD DoMore H2s. I am sure people have done this before so I was just looking for some tips of tricks before I get started. Is there anyway to import/convert the tag database or even the actual program? Is there any specific instructions I may have trouble with? Any DoMore features I should be using?
There is a documentation import facility, but it does not do a direct import. You will probably need to export a sample from the Do-more and then massage the AB documentation to match.
I suggest using the free video training coupon that comes with the Do-more processor. It should give you a boost toward learning what the differences are.
Also there are a ton of videos on the AutomationDirect YouTube Channel.
The help file is pretty well fleshed out so help can be found there as well. If all else fails, we do have free technical support so give us a call at 1(800) 633-0405 and ask away!
I’m currently starting a brand new design with a compactLogix controller and a panel view 700. I’ve completed similar projects from start to...
1,267
As I'm getting up to speed on some of the latest versions of TIA Portal, I noticed there is lots of security features. I'm wondering if anyone...
1,087
and go! I'll start. Always comment the Boolean instruction for their TRUE state. For example. It is much easier to read a normally closed contact...
65
21,758
I have been programming plcs and hmi's since the 90's. I would like to think that I have mastered my field/trade, but I know that I have not even...
859
My work laptop recently failed and I'm about to setup my new one. It will have RSLogix 500, Studio 5000, programs for - automation direct...
4,548
