Anybody have experience in Scattcon??
able lee
Jun 2006
china
18
HI, my friends:
now, i am USING ABB PLC -"Scattcon 35" ,have the software DOX10
my question is the word variable "AS" ,have the function analog status ,range from AS0--AS4. but i am not sure the detail function used in the system.
in my opinion ,when the 4--20mA analog signal failure above high limit or below low limit,etc.then the word assigned value
i am not sure my opinion is right
please my friends give me the right answer
thanks in advance
Hi able lee.
It is approximately 15 years since I had the opportunity to work with sattcontrol.
Is DOX10 the programming environment that looks like EDLIN ? If so, I pity you.
I cant help you much, only be sure to spell it "Sattcontrol" when you look for manuals.
Same here but then it was DOX5, it's awfull, dos based, no ladder no monitoring only by address bin it & get a real plc.
totally right ,the software based on DOS system, the client provide some manual about DOX10 ,but have no some DOX5.
IF anyone have some nanual about DOX5, Please free for send
thanks in advance
PLCNext: anybody have any experience with them? We are considering them as they have .Net Integration. I am wondering if anyone else has any...
7,700
I started working with a KUKA robot that has an Beckhoff plc running in the background. Would need some help with the ST code there
3,175
Anybody have experience on D_ACT_DP block in Tia portal? one of my project I use Siemens S7-300 CPU316 DP/PN connected to 5 station of ET200s...
3,291
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
123
Hi All, At work we primarily use Rockwell products and they are pretty good to work with and rock solid for industrial environments. A little...
1,073
