Anyone used the RSLinx Classic API/SDK?
sanger
Nov 2005
Toronto
172
I'm developing a C# application that will collect data via RSLinx. I have done this before using OPC but for this application I would prefer that the user not have to go into RSLinx and set up OPC Topics, etc.
Ideally I would like the program to be able to browse through the available PLC nodes (similar to RSWho view) and drill down into the tag lists. Is this possible through the RSLinx SDK? Are there any other API's other than the RSLinx SKD?
Speaking of the SDK, is this even available to end-users or do you need to be a Rockwell partner to get access. I've been unable to find any information on the Rockwell site about it.
Thanks.
I've been getting some advertising related to the attractively packaged Wago Compact Controller, model CC100, lately. As far as I can tell it's a...
2,218
Hi all, I have a client that has a water tank with a loop powered level sensor; the 4-20mA loop goes through a telephone line, half a mile away...
26
6,984
I'm working on a temperature/humidity test chamber that was made in China sporting a TATO PLC that looks exactly like a Micrologix 1000. Also has...
3,285
I have been scouring the internet over the past few weeks trying to learn about Hart-IP. Does anyone know, if I have a Hart-IP device, should I...
3,130
